4L80E swap - fuel line routing
Old Aug 28, 2018 | 09:15 PM
Brett_04Silverado's Avatar
Default 4L80E swap - fuel line routing
Swapping a 4L80E into a 2004 Silverado 1500 that used to have a 4L60E
The 4L60E had a boss on the driver's side of the transmission case for a bracket to secure the fuel lines. Not the clip at the bellhousing - this is further down above the shift mechanism. The 4L80E does not have this feature; looks like the 2500 fuel lines are completely different and attach to a bracket at the rear speed sensor.
For those who have done this swap - how did you secure the 1500 fuel lines? Not really comfortable letting them hang on the flexible section to the frame.
While the engine and transmission are out, I replaced the fuel lines with new stainless ones. The replacements have a GM quick connect flare where they come off the frame rail near the driver's door. Thinking maybe the easy way to handle this is with quick connect to AN adapters at the frame rail, then run braided stainless lines all the up to the engine over the transmission.
MikeGyver
27
Mar 17, 2020 01:59 AM
mcfarlnd
May 25, 2012 04:52 PM
bentrek
Apr 24, 2011 08:28 AM
SRTKLLR
Mar 30, 2011 06:51 PM
