4l80e swap completed
Old Mar 13, 2015 | 11:45 PM
natejk's Avatar
8 Second Truck Club
Default 4l80e swap completed
Just finished my swap just a few issues to cover for the next guy, stock shaft will work 7in yoke 447 u joint for the 1350 to 3r and 534g for the rear, also had an issue where it was in limp mode and it ended up smoking the forward clutches and welding them together, I had the trans built and they didn't replace the VSS or OSS so when I reinstalled it would shift 1st 2nd and then do some weird things I measured resistance and found a bad OSS also the abs light was on indication of bad OSS or VSS swapped sensors it now works perfectly also recommend dirttrackracer's crossmember it works flawlessly if anyone has any questions feel free to pm me thanks to this informative site making it a smooth swap
Old Mar 14, 2015 | 06:13 AM
iamkeniff's Avatar
That's one long a$$ sentence
Congrats on the swap
What was the reason it was in "limp mode" causing it to burn itself up basically?
Old Mar 14, 2015 | 02:29 PM
natejk's Avatar
8 Second Truck Club
Haha sorry I have terrible punctuation haha it was a bad output speed sensor speedo was working properly at first so I didn't know at the time what caused it but when I got it rebuilt the speedo went all over the place and my abs light was on so I ohm'd out both vss and OSS and the OSS was 8.7M ohms vs vss at 1517 ohms
Old Mar 15, 2015 | 02:15 AM
iamkeniff's Avatar
Ahhh that's some good info for someone that may have that issue later on
Old Mar 15, 2015 | 09:59 PM
natejk's Avatar
8 Second Truck Club
I figured I'd just post it for someone who may be actually using the search function haha
Old Mar 16, 2015 | 08:54 AM
tgui's Avatar
You didn't shorten your rear driveshaft?!
Old Mar 17, 2015 | 11:20 PM
natejk's Avatar
8 Second Truck Club
Negative I actually had PST make me a shaft and it was literally the exact same length of my stock one
Old Mar 18, 2015 | 08:32 AM
tgui's Avatar
I'm still new and learning.
I'm swapping a 4l80e into my 2002 Yukon. Is there a chance I don't need to mod my stock rear driveshaft?
Old Mar 21, 2015 | 08:13 PM
natejk's Avatar
8 Second Truck Club
It depends on what you have in my case I used a 1350 7" slip yoke with a moog 447 joint to my stock drive shafts and it was fine I upgraded to a pst drive shaft
Old Mar 23, 2015 | 11:27 PM
Wrecker 426's Avatar
So how long is a stock slip yoke?
