4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
#263
New NSS mounts made. I hear what wolf was saying but if I can't get the old NSS off easily, I'll want an easy way to prep it for mounting on my setup.
New mounts are cut in a way to be adjustable.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-siesgwa.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156446d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-siesgwa.jpg)
Bolted backwards with longer bolts. Backwards ensures room for bolts into NSS having room. Funny, stock mount under my truck only has one bolt.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-ftzu6o1.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156447d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-ftzu6o1.jpg)
Test fit. I have many rads of adjustment.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-ymlltkz.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156448d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-ymlltkz.jpg)
#264
Thanks! I'm all set though. Now finish your turbo.
#266
Shift selector and stuff done.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-5lwy0at.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156439d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-5lwy0at.jpg)
Ghetto fabulous!
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-wwcdito.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156440d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-wwcdito.jpg)
New rear band in place.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-tzaq33y.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156441d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-tzaq33y.jpg)
Center support and gears. I had to get that tool today. Too heavy to lower with finger tip. And I gots strong fingers and palms if you know what I mean!
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-d5komhy.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156442d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-d5komhy.jpg)
Center support bolt hope won't line up if you use the wrong case snap ring. Ask how I know....
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-gcbftct.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156443d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-gcbftct.jpg)
End play checked and good!
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-y1qrene.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156444d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-y1qrene.jpg)
Center support bolt torqued to 32 ftlbs.
![4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....-xntqzhr.jpg](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/156445d1683128419t-4l80e-rebuild-2002-yukon-swap-slowwwww-build-xntqzhr.jpg)
Now fer dinner!
Ghetto fabulous!
Now fer dinner!
