4l80e problems after converter swap
Old Oct 17, 2015 | 05:38 PM
mhotrodscooter's Avatar
Default 4l80e problems after converter swap
So I decide to pull my 3800 circle d for a restall. Thought I'd put the stocker back in so it wouldn't be down. Trans never been the same since. 1-2 shifts were slow, and now every time I switch gears are come to a stop it won't pull. Kill the truck and start it and it pulls till the next stop. Stock 80 with a hd2 kit. Been beating on it for close to a year. Working fine till I swapped converter.
Ohm the force motor it's at 4.8
Trans pressure falls on the first shift. And goes up and down around 20-40 psi
I'm lost so if anyone can help I'd appreciate it.
Old Oct 17, 2015 | 06:16 PM
smokeshow's Avatar
Mod with training wheels
The stock converter didn't have any crap in it did it?
Old Oct 17, 2015 | 07:06 PM
Idk I never ran it!
Old Oct 18, 2015 | 11:21 AM
01silvy's Avatar
If your line pressure is dropping that low and shifts are weak and sluggish then i would auit running it until you figure out whats going on.. Your going to kill your clutches quick with it acting like that.
Old Oct 18, 2015 | 11:35 AM
GMCtrk's Avatar
was fluid level properly checked
Old Oct 18, 2015 | 12:40 PM
Vortec350ss's Avatar
This sounds like low fluid to me too... the stock converter will hold a lot more than the circle D does. How much did you toss in it before installing it? If it was just a quart you are definitely low...
Old Oct 18, 2015 | 09:01 PM
If I unplug the main harness and replug it it holds pressures till I clear the codes. It was a quart low and fluid and nothing changes. Once I cycle the key I can take off and hit all the gears and it pulls fine till I let off and then it loses pressure
Old Oct 18, 2015 | 09:07 PM
Really I thought I had to be careful for ballooning. I didn't add any because it was the converter that came with trans and had fluid in it
Old Oct 18, 2015 | 10:29 PM
it had fluid in it... hmmm. I was just thinking that you pulled more than a quart out with that circle D, and the stocker will hold more. I'd give the fluid level another check and try over filling it by a hair... in stock form the dip stick tends to hang a tad low causing a slight under fill. With a performance application we tend to move more fluid and slosh what is still in the pan more making us much more prone to sucking the pan dry and losing hydraulic pressure.
Old Oct 19, 2015 | 12:03 PM
I'm going to change all the solenoid and try that with a new filter and fluid pcs was a little out of range so hopefully that fixes it. If not I guess I pull and tear it apart
