4l80e pressure control circuit
Old Oct 7, 2018 | 01:15 AM
Craig01's Avatar
Registered User
Default 4l80e pressure control circuit
I have a 2000 Chevrolet K2500 with a 4l80e transmission. The truck ran fine earlier this year, but has been parked since April. I drove it for the first time the other day, and the transmission shifts hard. Scanner shows zero volts or current draw going to the pressure control solenoid while driving. I tested the C and D terminals on the external wiring harness going into the transmission. The meter shows no voltage between the terminals. Should voltage be present at the pressure control with the truck off and the ignition on? If so how do I trouble shoot the wiring starting at the transmission connector? Does the power come directly from the ECM / PCM? Can a continuity test be performed between the Transmission connector C terminal and the ecm? If so, what connector and pins on the ECM corresponds to the transmission connector pins for the purposes of checking continuity? The check engine light is not on while driving and no DTC's are present.
TAPyvehc93
Jul 11, 2021 10:35 PM
Wrecker 426
Feb 28, 2017 07:45 PM
Mean Green z28
Dec 8, 2016 04:06 PM
turboal1
Dec 7, 2016 02:24 PM
crashmymax
Nov 20, 2016 07:39 PM
