4L80e pan wont fit. help!
Old Mar 16, 2013 | 04:05 AM
Ron_Stoppable's Avatar
Default 4L80e pan wont fit. help!
I have a 95 4l80e out of a van. i decided to swap to a new pan that has the drain plug. its AC delco part #24204278. i went to install it and it wont even lay flat on the rear of the pan because that rear bushing lube tube sits up too high. the pan has more shallower angles than the stock pan that was on it. fml. someone help me out. what exactly do i need? all i want is a stock pan with the drain plug. is the one i have for newer 80es or something?
Old Mar 16, 2013 | 07:59 AM
03sierraslt's Avatar
The older pans had the drain on the side of the pan. They are different then the newer pan.
Old Mar 18, 2013 | 01:36 AM
im returning it to amazon tomorrow. would you happen to know the part # for the correct pan i need?
SloSVO
Nov 22, 2020 07:34 PM
jscherbs
Sep 30, 2015 07:54 AM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
