4l80e noise, does it ever end? (Good things happen to good people)
Old 03-17-2008, 11:53 AM
KySilverado's Avatar
I don't like all the threads about 80E's going out. These are suppose to be the fix all for transmissions. I feel for you. I hate pulling a transmission myself.
Old 03-17-2008, 07:11 PM
9 Second Truck Club
stock48's Avatar
Hope it's something simple. It that a stock trans?
Old 03-18-2008, 06:57 PM
Kerr's Avatar
that sound cant be good.
Old 03-23-2008, 05:15 AM
How do I change this text
Wilde Racing's Avatar
a little update.....
Finished pulling the trans today, then I got motivated and tore into the trans. And of course as luck would have it, I dont have a 12point socket at home to remove the center support bolt. So close, yet so far away. I can spin the output shaft and hear the noise, so I must be getting closer.
Originally Posted by dewmanshu
Well, get your *** over here and pull mine then if you are so good then. LMAO Sorry to here about the damage.
You buy the gas, I'll be there!
It is the fix, my trans has held up very well for what I put it through.
The trans I ordered through Speed Engineering almost three years ago. I know very very little about the trans, other than the fact it is a very old style housing (has the oil cooler line at the same location as the 60e)
Old 03-23-2008, 07:05 AM
Bill Reid's Avatar
Everything else look good? Maybe just a freshen up since yer in there?
Bill
Old 03-23-2008, 10:58 AM
Destroyer of Transmissions
1SlowHoe's Avatar
5 times huh? I laugh at your 5 times
I can pull the trans out of my Tahoe in under an hour now. Wait...that's not a good thing
Hope it's a simple fix
Old 03-23-2008, 01:01 PM
Ya I don't have much to bitch about to you! Lol. Everything else looks ok, I'm going to give flt a call for parts.
Old 03-24-2008, 09:06 PM
***UPDATE***
Well, I got the output carrier out. I found I lost the needle bearing in one of the planet gears...................
What caused the bearing to fail??????????
Will the 02 5 pinion planetary fit the older trans?
Old 03-27-2008, 12:56 AM
Nevada79's Avatar
Post
I'm no expert but I would have to say the rear mount turbo...Time to switch to a front mount.
Sorry about the trans but glad you found the problem.
Old 03-27-2008, 07:01 AM
Somewhere in my readings I remember an oiling issue in the planetaries but I believe it was someone not recommending going to a 5 gear because of it.
Quick Reply: 4l80e noise, does it ever end? (Good things happen to good people)
