4L80E Low Gear Planetary
Old Mar 21, 2005 | 01:14 AM
Keith's Avatar
Default 4L80E Low Gear Planetary
I have searched here, summit and jegs and have found nothing.
Is TCI the only company that makes the low 1st and 2nd gear planetary sets for the 4L80E?
First changes from 2.48 to 2.75 and second changes from 1.48 to 1.57.
Would the computer need to have it's shift points re-calibrated?
Any ideas?
Old Mar 21, 2005 | 09:43 AM
Yank's Avatar
LS1Tech Sponsor
WE have the 4l80-e 3.0 low and 1.57 2th gear sets in stock
call me
Mike
Old Mar 21, 2005 | 10:41 PM
one03sierra's Avatar
Formerly one92rs
Talking
when you stick in an 80e you will have to run a pcm for a 6.0 and 80e combination. im running one from a 2002 2500hd truck.
Old Mar 25, 2005 | 11:56 PM
Keith's Avatar
Thats the thing. I'll dream for the rest of my life to have the torque to need a 4L80E in my truck.
This would be going in my dad's OBS 1999 Chevrolet 2500 CCSB. It has a vortec 350 in it with a 4L80E behind it, connected to a 9.5" Semi Floater 14 bolt. We were looking to stick a 5.3L block bored to the 5.7L size or a 6.0L, to get a more efficient engine in it.
I figured the low gear set would keep the about the same overall first gear ratio with a swap from 3.73 to 3.42 gears in the back and get a better overdrive ratio. Just thinking out loud and wondering what you guys think.
Old Mar 26, 2005 | 12:01 AM
Coan does them and I think Hughes does them to.
Old Mar 26, 2005 | 10:47 AM
BlownChevy's Avatar
blownerator
25 Year Member
Hughes....
Old Mar 27, 2005 | 01:24 AM
Keith's Avatar
You guys rock.
Old Mar 27, 2005 | 11:48 AM
James B.'s Avatar
The gear ratios are programmable to hundredths accuracy in the computer.
Personally, I love the stock ratios in the 80. With a stock 13" torque converter the engine stays up in the power band after a WOT shift better than it did with the 60 and a converter stalling at 3000. The closer ratios seem to outperform the greater range of ratios in the 60.
Old Mar 27, 2005 | 12:11 PM
Keith's Avatar
Thanks for the info about reprogramming the computer.
The stock ratios should keep you in the meat of the powerband a lot longer.
Old Mar 27, 2005 | 08:49 PM
Dark Halo's Avatar
you have to swap pcms or can you just have yours retuned?
