4L80e: Which gears?
Old Oct 19, 2005 | 09:50 PM
Default 4L80e: Which gears?
3:90 or 4:10's I think I heard that the 1st gear is shorter compared to the 60. So would 3:90's be better. I plan on doing a 3400 stall when I put the tranny in.
Old Oct 19, 2005 | 09:53 PM
NoChrome's Avatar
My HD came with 4.10s stock and I love them... well not the gas mileage, but nothing can beat the looks you get powersliding a 6000+ pound truck through an intersection
Old Oct 20, 2005 | 12:48 PM
I am running a 28.5" tall tire. I am sure your tire is a little taller.
Old Oct 20, 2005 | 02:49 PM
I think I might go with 4:10's since I run 20's on the street.
Old Oct 20, 2005 | 03:00 PM
dewmanshu's Avatar
Moderately Differentiated
I have the 80e, 31.22 is my outside diameter and I am running 4.10's with a 2800 stall. I love them. If I had to do it over again...hmmm...I might of went with 3.9's, what are you upgrading from? 3.73...then goto to the 4.10. 3.4's then goto 3.9. Just my 2cents. 28.5 might make those 4.10's awefully "revvy". I always hated the gear picking thing...it's all about what you like...good luck nevertheless and let us know which you end up with and how you like them.
Old Oct 20, 2005 | 05:18 PM
Breeze's Avatar
11 Second Truck Club
I beleive my tire is also 31.22 they are 285/50/20 anyway my 3.90s are perfect for my liking.
Old Oct 20, 2005 | 05:48 PM
NoChrome's Avatar
i think its like 245/75-16 or somthin...stock, well the fronts are stock, but Im on my 3rd set of rear tires, some how they go bald really quick, and shes only 9mo old.
Old Oct 20, 2005 | 10:01 PM
I guess since I am on 20's and like my ***** to the walls, I will go with 4:10's
Thanks for the help.
Old Oct 21, 2005 | 10:48 AM
I did some research and here is what I found.
6000 rpm redline, 28.5 dia. tire, with tranny ratios at 2.48 for 1st, 1.48 for 2nd and 1 for 3rd
These are the speed at the shift point at redline
------ 1st - 2nd - 3rd
3.90 - 52.78 - 88 - 130
4.10 - 50 - 83.6 - 123
4.56 - 44.98 - 75.38 - 111.56
I might do 4.56 gear, but this will greatly reduce my top speed. I think 4.10 are just going to make up for the swap.
Old Oct 21, 2005 | 06:10 PM
NoChrome's Avatar
Be careful, the pinion gear gets small the numerically higher the gear and the 10bolt isnt the strongest rear end to have any way.
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
