4L80E Full Manually shift .. Which Shifter??
Old May 26, 2006 | 11:45 AM
EL_3grab's Avatar
Default 4L80E Full Manually shift .. Which Shifter??
Hello there
Im doing a LQ4 with 4L80e swap to my Landcruiser .. I will use the Edelbrock Victor Jr. Carbureted Intake Manifold Packages with Transgo 4L80-E 3 reprogramming shift .. i have a hard time to find a shifter that will work with my setup .. with the usually
pattern shift P N R D321 ..
advice please ..
Ghanem
Old May 26, 2006 | 12:24 PM
You might have to make you own, why do you want to run a LQ4 with a carburator instead of a 350 SBC? Having a 350 SBC making 300 hp is cheap, unless you already have the LQ4. If you have the LQ4, is it a complete enginek, or just a long block?
Old May 26, 2006 | 01:20 PM
EL_3grab's Avatar
yah .. i have the LQ4 right now .. but without the Harness and ECM .. it would be cheaper to me now running the Carbureted Intake .. Im planing to have the EFi in the future .. maybe after 2, 2.5 year ..
Old May 26, 2006 | 01:43 PM
lokar does one,try Summit or Jegs.You might consider a TCI stand alone computer so you can lock the converter if you are planning any street use.
Old May 26, 2006 | 01:56 PM
EL_3grab's Avatar
with the full manual shifts no computer or wiring there ..
Old May 26, 2006 | 02:52 PM
EL_3grab's Avatar
i contacted Lokar .. they have what im looking for .. thanks evey one
Oobray
Jun 13, 2022 03:38 AM
chvy=power
Sep 8, 2015 11:05 AM
Blackrat48
Aug 16, 2015 11:56 AM
dantheman1540
Jul 24, 2015 01:50 AM
Ketis
Jul 23, 2015 12:37 PM
