4L80E converter options
Old May 27, 2013 | 12:45 PM
tennerv8's Avatar
Default 4L80E converter options
Picked up an 80E for my LQ4 s10. Truck will have a turbo shortly. Should be around 600-700whp. I have a 373 gear in it currently.
Im installing a transgo HD2 in it. And am going to use a OptiShift controller. What are my converter options here? Not trying to spend $1200 just yet on one. Probably shoot for a 3500ish stall.
Old May 27, 2013 | 01:17 PM
Gadgetized's Avatar
I have a used one I will let go for 400. It is a Performabuilt race 3200 9.5". It needs to be gone through. I didnt send it in to freshen up in case the next owner wanted to change the stall when it was opened up to be gone through. It is 800 new.
Old May 27, 2013 | 02:09 PM
Atomic's Avatar
I have a gauge for that
So if your not wanting to spend $1200, how about $1100? Whats your budget...
Old May 27, 2013 | 02:56 PM
la_blue_SS's Avatar
Circle d 3200+ ... Can go wrong with billet
Old May 27, 2013 | 08:31 PM
Suburbazine's Avatar
If you're looking to spend less, I'd recommend a Precision Vigilante. You can get a good triple disc for about $750. It will be a LOT looser than a Circle-D though.
Old Jun 1, 2013 | 10:28 AM
tennerv8's Avatar
Thank you for the offer but i'd like to go with something new.
Old Jun 1, 2013 | 10:57 AM
La Chicken G B N L's Avatar
I have a nib converter stall speed should be around 3200 . It has a ls1 bolt pattern (3 bolt) ill let it go for 900 plus the ride .
Here is the discription straight from circle d website.
GM 258mm Pro III 4L80E Torque Converter
Pro Performance Stage I Billet Multi Disk Torque Converter
Converter Diameter - 258mm - 10 1/4"
Available in stall speeds from 2500-3500 rpm
Price: $1,100.00
Oobray
Jun 13, 2022 03:38 AM
GXPJAY
Feb 13, 2022 08:15 AM
Slow94Formula
Nov 15, 2015 09:23 PM
bighouse
Sep 27, 2015 12:37 AM
lycominghunter
Jul 29, 2015 04:24 PM
