4l80e 2x2 convert to 4x4
Old Nov 2, 2015 | 10:34 AM
Lajoieventures's Avatar
Registered User
Default 4l80e 2x2 convert to 4x4
I have a 2003 Silverado 2500 HD (automatic) with screwed transmission. Transfer case is fine. What modifications do I need if I have access to a rebuilt 4l80e 2x2 tranny? Is it worth it? What's the difference?
Old Nov 2, 2015 | 10:38 AM
tgui's Avatar
I am doing that very thing for my current build.
You need
- New shorter 4x4 output shaft
- transfer case adapter at the end of the trans
- Plug oil hole in rear of case
You'll have to take the trans apart of course.
Old Nov 2, 2015 | 11:31 AM
Atomic's Avatar
I have a gauge for that
And by apart, he means completely apart. The output shaft is at the very bottom.
Old Nov 2, 2015 | 01:18 PM
tgui's Avatar
Yeah, totally apart!
If you're going to go through the trans to check its health then its not a big issue. If you just want to drop one in quickly, not worth it.
Old Nov 2, 2015 | 01:43 PM
1bad2k's Avatar
Yep, like mentioned the trans will have to be completely torn down again to get to the output shaft which needs to be changed, and is at the VERY back. Might just be better to have yours gone through by a reputable shop at that point. Then you'll have a warranty and peace of mind.
Old Nov 2, 2015 | 01:59 PM
tgui's Avatar
Technically he could cut the shaft shorter and just plug the oiling hole, right?
Old Nov 2, 2015 | 03:29 PM
Registered User
Thx all for the input. I'll just get one that needs no modifications. I Don't have much time till the snow flies and no time for dismantle. Just mechanically inclined enough to do the switch. Appreciate the advice
97aztecgt
Nov 10, 2015 05:36 PM
Blacktravis
Nov 8, 2015 08:57 PM
jdb11386
Oct 29, 2015 06:45 AM
zz4camaro1980
Oct 28, 2015 08:17 AM
vipergtrdj
Oct 27, 2015 03:19 PM
