4l65e tranny question no 2nd gear
I have a 08 rcsb 4.8 100k miles on it cam headers etc.. i have every gear including overdrive except i dont have 2nd gear..tranny is stock..
most likely has a worn band...the 2nd gear servo does not travel as far as 4th servo, so usually 2nd is lost first then 4th is close behind..
If money is tight you can extend the servo pin .150-.200...will get you by for a while
Also check the 1-2 acc. piston..if its plastic it can crack..replace it with aluminum..very easy to do from the pan area
