4L65 question
Old Nov 27, 2011 | 01:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Found it. Here is how to get the measurments before installation.
https://www.performancetrucks.net/fo...ations-406113/
Old Nov 30, 2011 | 03:23 PM
nonnieselman's Avatar
Before gettin the bellhousing bolts tight i always spin the converter. Then tighten the bolts and check the converter one more time. Grease the snout that touches the crank. If you cant spin it with one finger before you pull it to the flexplate, you have a problem.
Old Nov 30, 2011 | 04:17 PM
1FastBrick's Avatar
Good advice.
Old Nov 30, 2011 | 04:40 PM
CaRaZy's Avatar
When you had the pan down did you check and make sure the manual valve was hooked up to the linkage and the right filter was used (all black plastic)? Sometimes builders could have missed that but the pump being damaged is possible during install. If you dont have any fluid coming out the cooler lines you obviously have no pressure which leads to pump.
blownss27
Aug 14, 2020 08:27 AM
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
