4L65 AWD vs 2wd output shaft difference???
Old Apr 15, 2009 | 05:13 PM
Turbocoop's Avatar
Default 4L65 AWD vs 2wd output shaft difference???
I know Ive read about this before but I cant find it now- Is there a difference between the AWD/4wd output shaft and the one that comes on a 2wd truck? Mines a 4L65 but I guess its the same with a 4L60. I know the tailshaft housing is different, obviously, but is the output shaft itself the same length and does it have the same number of splines on it?
I need to put my 4L65E in a 2wd truck so I want to know what I need. I will have the tailshaft housing from the 4L60 in the 2wd truck, but will the output shaft from my AWD 4L65 fit in the slip yoke on the 2wd driveshaft?
Old Apr 15, 2009 | 06:23 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
No the AWD is too short you would need to disassemble the trans and swap the output shafts
Old Apr 15, 2009 | 07:30 PM
Turbocoop's Avatar
damn thats what I was afraid of, oh well just some more work for me but it'll be worth it. Thanks
They are both 27 spline though I found that out
Old Apr 15, 2009 | 07:36 PM
006rcsb's Avatar
but the 4l65 that has the awd system on it and the 4l60 that has an autotrac t-case behind it have the same output shaft right?
Old Apr 15, 2009 | 08:08 PM
kbracing96's Avatar
The 4wd and Awd, are the same output shaft on the trans.
Old Apr 15, 2009 | 08:48 PM
budhayes3's Avatar
PT's Slowest Truck
You have to basically tear the whole trans down to change the output shaft...
Old Apr 16, 2009 | 06:57 AM
Turbocoop's Avatar
I know Ive done it before, it sucks but I gotta do it
Bumpers
Aug 4, 2024 09:44 PM
chopperloco
Jul 10, 2016 10:45 PM
Abuckeye
Aug 19, 2015 06:11 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
alex226
Jul 16, 2015 10:55 AM
