4l60e Trans temp sensor
Old 07-19-2013, 07:37 AM
Slowest_1500's Avatar
Default 4l60e Trans temp sensor
I'd like to figure out where to install the sensor for my Trans temp gauge? It's a glowshift gauge if that helps?
Old 07-19-2013, 07:53 AM
Slammed96's Avatar
I would just tap it into the pan. Just make sure to clean up all your shavings really well.
Old 07-19-2013, 08:28 AM
jvoisel's Avatar
Pressure test port.
Old 07-19-2013, 08:31 AM
Originally Posted by jvoisel
Pressure test port.
NOOB question, where is it located actually? any potential problems running it there?
Old 07-19-2013, 08:35 AM
jvoisel's Avatar
Not a noob question. Located on the drivers side above the shift linkage crap. There's a 11mm plug you'll have to pull out and the new sensor should thread in. Mine was 1/8"npt x 1" long and works fine.
Old 07-19-2013, 08:58 AM
Thanks a ton man!
ullose272
08-05-2016 02:05 PM
brandon6.0
08-19-2015 07:48 AM
Matt C.
08-01-2015 01:25 PM
ferrellrooster
07-13-2015 09:53 AM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: 4l60e Trans temp sensor
