4l60e Trans temp sensor
I'd like to figure out where to install the sensor for my Trans temp gauge? It's a glowshift gauge if that helps?
I would just tap it into the pan. Just make sure to clean up all your shavings really well.
Pressure test port.
Originally Posted by jvoisel
(Post 5126511)
Pressure test port.
1 Attachment(s)
Not a noob question. Located on the drivers side above the shift linkage crap. There's a 11mm plug you'll have to pull out and the new sensor should thread in. Mine was 1/8"npt x 1" long and works fine.
Attachment 113105 |
(Post 5126513)
http://i1120.photobucket.com/albums/...ps959fef62.jpg |
