4l60e trans questions
Old Apr 3, 2012 | 11:56 AM
2000SIERRA's Avatar
Default 4l60e trans questions
I have a 99 GMC with a 5.3 and the 4L60e trans. Truck is 100% stock with 174000 miles on it. Trans has no reverse, and the only code I am getting is a P0751, 1-2 shift solenoid performance. What are the chances that my problem is just a bad solenoid? Thanks for the help
Old Apr 3, 2012 | 07:02 PM
Vince B's Avatar
The shift solenoids in the trans have no effect on reverse function. If I had to guess you have a clutch pack that is keeping reverse from working. It could be either the the low reverse or the reverse input clutch. You could even have a clutch that is welded together that is used in one of the forward gears. This would bind up the trans when you place the shifter in reverse. Thus your no movement in reverse. Vince
Old Apr 3, 2012 | 08:28 PM
2000SIERRA's Avatar
Thanks for the reply, guess I'll just swap a 80e in it and be done with it
Old Apr 4, 2012 | 06:04 AM
Vince B's Avatar
With the miles you got on that 60 I do not see a reason to swap to an 80. I would just have it rebuilt or replace it with a low mile unit and run it.
Old Apr 4, 2012 | 12:38 PM
2000SIERRA's Avatar
Well I just bought the truck, and my plan is to eventually swap to a turbo 6.0, that's why I figure to swap to the 80 now
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
ferrellrooster
Jul 17, 2015 07:07 AM
grantpo
Jul 15, 2015 12:21 PM
