4l60e issues
Old May 21, 2006 | 11:04 AM
  #61
im not talkin about a stock 60 vs a race set up, you cant judge how strong parts are if you see them under different conditions because these is no control. IF you put a stock 60 in a stock truck it would last IF you put a race 60 in a stock truck too it would last. IF you put a stock 60 in a race set up it wouldnt make it down the track IF you put a race 60 in a race set up at least it would get off the line so that seems to me that the parts would be stronger.....
  #62
we need to let this go because it has nothing to do with the thread...
Old May 21, 2006 | 11:39 AM
  #63
Quik's Avatar
5 year bitches!
my thread and its over, trans is fixed and performs well so far so yes its over
Old May 21, 2006 | 05:14 PM
  #64
OrlandoFL4.8's Avatar
I think the point here is that performance trannys with hardened parts and increased line pressure are able to engage the clutches better under harsh, high hp circumstances, as for a stock set up would slip alot more which would create more heat and destroy the stock set up under the same high hp application. That same agressive behavior however can shorten the life of the performance tranny, even under normal driving conditions, that were designed to save it from harsh driving conditions. I think the key here is not to have the shifts set up so firm that it unneccesarily causes stress on even the hardened parts, but just enough to allow the hardened parts to do their job when needed. My last built one would chirp 2nd gear on certain types of pavements under normal throttle, that is how hard it was set to shift, and I think that could have had a lot to do with its short life. Sometime before I get my built one from FLT, Im gonna talk to them and see what their take is on this. I also had TM completly removed when I got the VCM mail order tune, and may be having it retuned based on what their take is on that as well.
Old May 21, 2006 | 06:43 PM
  #65
TouchOfEvil04's Avatar
Originally Posted by Soon2bSpooled
where did you find someone to warranty their build? that seems like a pretty good deal to me
I used a guy that I knew about before the tranny went.My best friend had used him a few years back and the tranny was still strong as it was since day one and never ahd any problems from it.
So i went to Morris Transmissions off of Choctaw in B.R.
He built it for 700hp for $1724.00 plus tax....
Then he gave me the warrenty that i stated before.
Great guy and does very good work.I'd recommend him to anybody.
Old May 21, 2006 | 09:54 PM
  #66
touch, what state was this guy located? it would be nice to have a built trans for 1700$ with a warranty...
Old May 21, 2006 | 09:59 PM
  #67
Same as i live..In Louisiana and the shop is off of Choctaw.I can see about finding my paper work tomorrow and PM you a number to him.
Old May 21, 2006 | 10:00 PM
  #68
sounds good a number or email....i would like to put in the built trans before my stock goes out....i think its gonna crack once i put the new cam in anyways
Old May 21, 2006 | 10:58 PM
  #69
FLT's Avatar
FLT
FormerVendor
I do a level 4 with a warranty for $1850. Here is a link for you.http://www.finishlinetrans.com/trans...60E-Level4.htm Let us know if there is any thing we can do for you!!
Thank you, Vince.
Old May 21, 2006 | 11:30 PM
  #70
what limitations do you have on your warranty or is it along the lines that if it breaks you fix it no matter what?
