4l60e build with $100 core...
Old Apr 14, 2016 | 12:26 PM
  #391
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Wolftrk99
I will, have to get to my laptop when i get home before 11pm!!! But i think ive narrowed it down to fact that the 1-2 shift speed is set at 26mph, which as tight as old converter was was fine, but with the tb and bow the circle d, not so much!!!
If you're referring to it being under WOT when shifting short, then yes it's commanding the 1-2 shift at 26MPH. You probally need to raise that.
Old Apr 14, 2016 | 01:06 PM
  #392
Wolftrk99's Avatar
Thats what i figured, even when i drop it down to first, it still shifts to 2nd at about 26mph, hadnt paud attention to the speed until now... Was more concerned with consistent 1-2 at 3500rpm.... Im gonna play with it tonight, hopefully... Thinking ill bump it up to 40 or 42 and see what happens, wish i had the stock file to see what it was originally set at..
Old Apr 14, 2016 | 01:18 PM
  #393
1FastBrick's Avatar
try 35 first.
Old Apr 14, 2016 | 01:20 PM
  #394
1FastBrick's Avatar
Looks like 25 was a factory number.
Old Apr 14, 2016 | 01:30 PM
  #395
Wolftrk99's Avatar
Thats weird the factory tune in the yukon had 1-2 at 40....
Old Apr 14, 2016 | 01:38 PM
  #396
1FastBrick's Avatar
I looked at a base 5.3L file from 99 and that's what it showed. 25MPH
Shows 4.10's as the gear ratio.
Tires and gears will also play a role.
Old Apr 14, 2016 | 01:43 PM
  #397
1FastBrick's Avatar
Just looked, Mine was changed and set to 41 in my old 2000 truck.
25 was the stock value in the original base file.
I guess go straight to the 40 and see what she does.
Old Apr 14, 2016 | 02:29 PM
  #398
tgui's Avatar
I had mine at 33mph with the 60e and 4.10 gears. It worked well there.
Old Apr 14, 2016 | 04:27 PM
  #399
Wolftrk99's Avatar
Tgui, yourealso running stock tires correct?? Thinking with the 35s ill need more
Old Apr 14, 2016 | 05:13 PM
  #400
1FastBrick's Avatar
Mine were larger than stock, around 32in and a crappy 3.42 gear with a Circle D 2500 TBSS Stall.
Stock Engine too!
