4l60e build with $100 core...
Old Oct 4, 2015 | 01:29 AM
  #21
Wolftrk99's Avatar
Question while i'm not too far past it.... My front ring gear hub is the bearing style does that eliminate the thrust washer or do i still need the thrust washer with the bearing??
Old Oct 4, 2015 | 01:43 AM
  #22
1FastBrick's Avatar
Custm2500's Rude Friend
A bearing would eliminate a bushing or thrust washer.
Old Oct 4, 2015 | 01:44 AM
  #23
Wolftrk99's Avatar
K cool just want to be sure..... You think that sprag is ok, even if when i was putting it back together one of the springs popped out??
Old Oct 4, 2015 | 12:18 PM
  #24
tgui's Avatar
The older a sprag the more it falls apart when yer pissed off trying to put things together.
Did it lock properly? If its dry it will squeal. I put some lube on mine when testing and it was silent.
Old Oct 4, 2015 | 12:25 PM
  #25
1FastBrick's Avatar
A Spring in the Sprag fell out???
Old Oct 4, 2015 | 12:33 PM
  #26
Wolftrk99's Avatar
Didnt really fall out came out from behind the roller while i was sliding the bearing back in
Old Oct 4, 2015 | 01:06 PM
  #27
Wolftrk99's Avatar
Race not bearing.....
Old Oct 4, 2015 | 01:07 PM
  #28
1FastBrick's Avatar
Got any pictures? I am trying to visualize where it came from and why it would fall out.
Old Oct 4, 2015 | 01:17 PM
  #29
Wolftrk99's Avatar
The accordian spring between the rollers in the sprag, don't know why it came out but i pulled race back out and put it back behind the roller and the race slid in....
Old Oct 4, 2015 | 01:19 PM
  #30
Wolftrk99's Avatar
Im gonna pull it back out tonight or tomorrow night and double check it and lube it up....
