4l60e 4x4 output seal
Old Aug 8, 2014 | 06:05 PM
truckmann's Avatar
Default 4l60e 4x4 output seal
2003 silverado 4l60e 4wd. I took out the transfer case because it was leaking between the transfer case and transmission. The fluid is red so I'm assuming its transmission fluid. Am I right to assume there is not an easily serviceable seal on the output shaft and that the only thing keeping the fluid in there is the seals on the adapter?
Old Aug 8, 2014 | 07:35 PM
GMCSIERRA5.3's Avatar
Only a orange seal on the case and from tailhousing to transfer case theres the gasket thats it
Old Aug 8, 2014 | 08:10 PM
truckmann's Avatar
That's what I thought. Thanks.
The nuts holding on the t case were a bit loose, so hopefully that explains the leak.
Old Aug 11, 2014 | 07:26 AM
built408's Avatar
A driveline vibration will cause the nuts to back off.
Old Aug 11, 2014 | 09:21 AM
truckmann's Avatar
Makes sense. I had to replace the rear u-joint a couple of months ago.
Old Feb 25, 2022 | 07:23 PM
Flmann407's Avatar
Registered User
So there's no output shaft seal on this style then correct just ext. Paper gasket and the rubber ring bolt seals keeps fluids in .. my transmisson shifts fine just losing fluid
Chavette
Oct 28, 2015 07:33 PM
maxspeed05V
Sep 23, 2015 10:48 AM
screaminian47
Sep 7, 2015 08:20 PM
mayko
Sep 7, 2015 12:24 PM
fctry286
Sep 5, 2015 11:48 AM
