4l60e to 4l80e swap questions
Old May 20, 2006 | 12:40 AM
Default 4l60e to 4l80e swap questions
i was wondering if a 4l80e can bolt up to a 4.3L? because i know they made for ls motors mainly so could i use the housing off my 4l60e and and the input shaft and it would mate right to the 4.3L?
Old May 20, 2006 | 12:45 AM
Quik's Avatar
5 year bitches!
but why? youre little motor isnt making no where near enough power to need a 80
Old May 20, 2006 | 12:48 AM
James B.'s Avatar
It's easier than you think. The 4.3 is classic Small Block Chevy®! It has the exact spacing and bolt pattern that the 4L80-E is designed for.
Use a lower bellhousing for a OBS 4x4 truck. That will be a cast aluminum piece instead of a stamped steel one.
The bellhousing of the 80-E is fixed and no shafts will swap over - totally different (and superior) design. You'll be a little bit on your own with the swap. I don't see many, if any, putting 80's behind the V6.
EDIT: Never mind Quik's comment. His 60 just broke and he's a little sore because he can't have an 80.
Old May 20, 2006 | 10:12 AM
well im building a motor w/ 270ah cam, 10:1 compression, fully reworked heads, and a 150 to 175 shot, so i think i need a built tranny and 4l60e's dont have best rep for keeping together under high hp
Old May 20, 2006 | 10:14 AM
Quik's Avatar
5 year bitches!
but you need to realize HP isnt want does it, torque kills. and for youre situation a 60 or a 70 would work better IMHO
ferrellrooster
Mar 6, 2025 03:22 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
