4l60e from 2 wheel drive to be swaped for 4l80e from 4x4 tailshaft questions
Old Dec 29, 2010 | 12:19 PM
files007's Avatar
Default 4l60e from 2 wheel drive to be swaped for 4l80e from 4x4 tailshaft questions
Hey guys I'm doing a motor and trans swap in my 2 wheel drive 03 silverado. it has a v6 with a 4l60e and I'm swaping in out with a v8 6.0 with a 4l80e out of a 4x4 2500HD. since I'm not using the transfer case I will need a tail shaft. my question. is the tail shaft on the 4l60e removable and can I put it on the 4l80e with no problems. all info is apreciated. Thanks
Old Dec 29, 2010 | 06:06 PM
Vince B's Avatar
You will have to install a 2wd output shaft in the 80e and also get an 80e tail housing for it. There is a lube orfice that will have to be installed in the back of the case. You will have to first remove a freeze plug that is in the case and then install this other seal/orfice to lube the extension housing bushing. Might as well freshen the unit up while its all apart. Vince
Old Dec 30, 2010 | 03:34 PM
files007's Avatar
thanks Vince. would you have a ball park number on what kinda money I will be spending in parts for all this. just trying to get my ducks in a row before I start this project.
Old Dec 30, 2010 | 07:15 PM
Vince B's Avatar
If I had to guess probably $150 shipped. Vince
Old Dec 31, 2010 | 11:13 AM
files007's Avatar
Thanks Vince...
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
Rafe19
Oct 18, 2016 12:27 AM
KyleW707
Jul 29, 2015 08:17 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
