4l60e 1-2 shift question
Old Dec 28, 2014 | 09:02 PM
cooter1989's Avatar
Default 4l60e 1-2 shift question
I have a 60 in a 00 Silverado stock tranny other than the pressure is manually boosted from the regulator. My question is why does it shift in to second while still in manual first? It will shift in to second on its own around 30mph. Is this controlled by the pcm or is it a manual override controlled by pressure in the valve body?
Old Dec 31, 2014 | 04:04 PM
cooter1989's Avatar
bump..
Old Dec 31, 2014 | 04:53 PM
FFDP's Avatar
I coulda swore the owners manual has a little blurb on why is does it.
But every auto I've driven will shift into 2nd gear when held in first if you reach a certain speed/rpm.
Old Jan 1, 2015 | 12:21 PM
cooter1989's Avatar
Im thinking its probably in the valve body. im assuming once the pressure builds it by passes the spring pressure and shifts it
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
06 4.8
Aug 21, 2015 11:33 PM
Ferocity02
Aug 7, 2015 08:50 PM
USMCvet0311
Aug 1, 2015 07:45 AM
