4l60 second gear slip
Old Oct 2, 2013 | 04:14 PM
bad cutt's Avatar
Default 4l60 second gear slip
So I've got about 1000 miles on my 4l60 in my turbo 03ecsb z71. I just rebuilt my trans about 1k ago and it was shifting excellent and I took off from a light the other day and when it shifted into second it was a really soft more of a slip into second. It had previously been very firm. Third is fine and obviously with lack of second there is no fourth. I'm wondering about the second gear accumulator or spring, any other ideas
Old Oct 4, 2013 | 01:27 PM
cwalker2006's Avatar
The band might of burnt up. I had a similar issue just didn't have 4th. And it was the band I believe
Old Oct 4, 2013 | 11:04 PM
TechGM's Avatar
Registered User
Check servo apply pin. Pry on servo cover with pry bar and socket and watch how much cover pushes in before it stops. Should be approximately half inch. This may tell you if your band is applying or maybe it broke off locator pin. If it gradually went into 2nd as you described vs. firm I'm wondering more so if it just went right into third cause trans saw it wasn't making 2nd gear ratio. And then that would help explain also no 4th.
Oh and also check the 1-2 accumulator too. Make sure that plastic piston didn't crack. Let me know what you find with these and I'll help you with more.
Old Oct 5, 2013 | 12:17 AM
bad cutt's Avatar
I have a metal accumulator piston its fibe the band broke off where the servo pin pushes on it. I've hot pics but not sure how to post
Old Oct 5, 2013 | 11:37 AM
whitedakota's Avatar
What brand/kind of servo do u have in it?
Old Oct 5, 2013 | 11:38 AM
TechGM's Avatar
Registered User
Good find. It's rare to see bands break there but I have seen it even in stock form vehicles.
Old Oct 5, 2013 | 03:20 PM
bad cutt's Avatar
I havea billet super servo
ferrellrooster
Mar 6, 2025 03:22 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Dezert1500
Jul 30, 2015 02:51 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
GMCtrk
Jul 17, 2015 06:39 PM
