4L60 Nightmare
Old Apr 26, 2009 | 11:06 PM
anfking6908's Avatar
Default 4L60 Nightmare
Well ive had hell since day one with my transmission ever since it overheated. It is throwing two codes right now. P0748 & P0706. I can clear the codes on my truck and as soon as i start the truck back up the 748 pops back up. I just hooked my tow/haul button back up b/c the guy i had rebuild it cut the wire. Well how hard would it be to check and see if he left the pressure sensor unhooked inside of the transmission? and can i do it with out dropping the transmission?
Old Apr 27, 2009 | 12:34 AM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Those two codes are not related codes and are both circuit electrical codes , I would suggest checking the wiring harness that its plugged in good and look that there are no wires exposed or pinched in the trans harness.
Old Apr 27, 2009 | 12:37 AM
Wheatley's Avatar
Truck Sponsor
How did I know Frank would post soon!!LOL
Good advise Frank
Old Apr 27, 2009 | 12:42 AM
Its what I do
Old Apr 27, 2009 | 12:45 AM
Wheatley's Avatar
Truck Sponsor
Thats a good thing
Old Apr 27, 2009 | 12:49 AM
Yep and check out the new addition to my signature
Old Apr 27, 2009 | 05:44 AM
yes all the wires are plugged in and none seem pinched at all
Old Apr 27, 2009 | 03:30 PM
You should also check that the internal harness didnt get pinched between the case and the pan a common enough builder error.
Old Apr 27, 2009 | 10:11 PM
how do i check the internal wires?
Old Apr 28, 2009 | 08:53 AM
Pull the pan and inspect over near the plug that the wires were not pinched between the pan and case
