4L60 to 4L80 dyno results
Old Jun 15, 2012 | 11:44 PM
black00chev's Avatar
Slowest turbo build ever!
Brent, did you have to replace both the rear and front driveshafts with shorter/longer ones when doing the swap?
Old Jun 16, 2012 | 12:32 AM
brent1976's Avatar
11 Second Club
Rear ds shortened 1 7/8", front yolks re-used with a new shaft lengthened 1 7/8". The rubber boot on the front of the transfer case set exactly where I marked it on the slip yolk. I think it cost $225 for both.
Old Jun 16, 2012 | 05:24 AM
TIM Z's Avatar
11 sec. Truck Mod
x10 thanks for sharing, great info.
I also was wondering how much more power is lost thru the tcase though.
I bet its safe to say the range of power robbed from 60e to 80e thru a 4x4 setup is roughly 20-30 horse.
But its hardly an excuse not to do an 80e when your ready to do a trans !
Old Jun 18, 2012 | 03:44 PM
foose04's Avatar
Great info and thanks for sharing!
Old Jun 18, 2012 | 10:08 PM
sureshot's Avatar
Great write up, and good job on trying your best to do a true apples-to-apples comparison!
Old Jun 18, 2012 | 10:55 PM
TX Tahoe Z71's Avatar
Great info, thanks!
Old Jun 18, 2012 | 11:21 PM
bigcountry119's Avatar
this is excellent
Old Jun 20, 2012 | 02:16 AM
Daryl T's Avatar
Registered User
So if I swap my 4L60E to a 4L80E, what are some of the things that I need to modify? My truck is a 1500 crew running 3.23 rear with modified 5.3. Thanks for any info.
Old Jun 28, 2012 | 01:24 PM
LS1TRUCKGUY's Avatar
there are a few ways to do it. you will need a conversion harness, or modify your stock harness, an 80e converter, or a custom converter, either an 80e flexplate or a crank spacer for your 5.3 flexplate, modify your trans crossmember, modify your trans cooler lines, shorten your driveshaft, or use the stocker with a th400 yoke.
if you modify your harness, you will need an 80e segment swap in your pcm to control the trans. if you use a conversion harness, its just plug and play
Old Jun 28, 2012 | 02:10 PM
nonnieselman's Avatar
Theres also a way to do the 60E tune with a couple relays and wiring..
