4L60 to 4L80 dyno results
Rear ds shortened 1 7/8", front yolks re-used with a new shaft lengthened 1 7/8". The rubber boot on the front of the transfer case set exactly where I marked it on the slip yolk. I think it cost $225 for both.
11 sec. Truck Mod
x10 thanks for sharing, great info.
I also was wondering how much more power is lost thru the tcase though.
I bet its safe to say the range of power robbed from 60e to 80e thru a 4x4 setup is roughly 20-30 horse.
But its hardly an excuse not to do an 80e when your ready to do a trans !
Registered User
So if I swap my 4L60E to a 4L80E, what are some of the things that I need to modify? My truck is a 1500 crew running 3.23 rear with modified 5.3. Thanks for any info.
if you modify your harness, you will need an 80e segment swap in your pcm to control the trans. if you use a conversion harness, its just plug and play
