4/6 drop w/ 265/50/20
Old Oct 8, 2007 | 04:13 PM
Deckhand's Avatar
Default 4/6 drop w/ 265/50/20
Im running centerline 20x8.5 w/ a 5.4" BS and BFG KDW 265/50/20's, which are 30.4 inches tall. I know the rears will clear because my fenders are rolled. Would the fronts be ok, or would it rub?
Thanks.
Old Oct 8, 2007 | 05:34 PM
bgray's Avatar
TOTM: June 2007
oooo....im thinking its gonna rub up front real bad.. my 255/45's do
Old Oct 8, 2007 | 08:28 PM
IMD's Avatar
IMD
Banned
hmmm my 275/45/20's dont rub :dunno:
Old Oct 8, 2007 | 08:31 PM
nightrunner's Avatar
Mr. Obvious
arent you 4x4, if so you ride 2" higher than a 2wd from the factory
Old Oct 8, 2007 | 09:17 PM
skyhighsami's Avatar
no title here
The wheels is what will make the rub on turns and bumps while turning. The hieght will cause the tires to hit the fenders. My truck has a 275/30/24 with a Bonspeed 24x10 and 7.5 inch of BS and they dont rub anywhere, except when turning up a steep drive way or on the interstate and the truck bottoms out. They are 30.5 inches tall, if I quite driving it everyday I will very likely pull the inner fenders.
Old Oct 9, 2007 | 12:44 AM
StrokerAce03's Avatar
It will rub; 275/45 is the max with that drop.
Old Oct 9, 2007 | 06:54 AM
dc96819's Avatar
It will hit the top of the fender well going over dips
The back is no problem,295/45/20 is a good fit for the back
Old Oct 9, 2007 | 09:33 AM
IMD's Avatar
IMD
Banned
not anymore. i removed all of that, and now it has coilovers on the front, and 2" spindles.
Old Oct 9, 2007 | 09:40 AM
RandomHero's Avatar
Judging by your pictures though you sit about 2" higher than I do and I have a 4/6 drop.
Old Oct 9, 2007 | 03:10 PM
IMD's Avatar
IMD
Banned
i dunno how to make it any lower. the camber is already wack!
