Is 4.56 the biggest gear available with 8.6" 10bolt?
#41
ok. Just one thing to consider: is it an off-the-shelf 2800 or one spec'd for your 4.8 and cam. Stall speed changes off of engine tq and a 4.8 with a moderate to large cam won't stall anything like a 5.3 or 6.0 with the same cam.
#42
true..but even with a 5.13 gear he should get off the line good and prolly spin the tires pretty easy
#43
i was talkn bout the vig2800 for ls1 fbody. i know its tighter behind the 4.8 but thatd what i want. thats also why i want so much gear. to make the converter tighter and able to lock up sooner.
there used to be a dyno of the vig2800 at yank. 97% efficency and its much lighter than the stock cvtr
#44
#46
I agree. I will say that a high stall with factory type gears and factory lock-up tunes are dramatic but a 2800 stall in a stock 5.3 does good with the lock-ups raised a little. I've tuned one and it did well. Stock lockup was waaaay too early and seemed like it labored the clutch in the converter.
97aztecgt
Aug 13, 2015 02:11 PM
