3 inch drop now have rear sway problem
Old Apr 21, 2011 | 02:20 PM
LT1TECH2003's Avatar
Default 3 inch drop now have rear sway problem
on my 2001 tahoe 2wd i dropped the rear with 3 inch eibach springs and now when i hit a bump on the road the rear sways.. i have 22's on it and they were on before the drop. i removed the bump stops to make sure that wasnt the problem. i have replaced the rear shocks and installed a sphon adjustible pan hard bar. cant seem to get ride of the sway.. just wondering if anyone else has had this problem before.. i also replaced the shocks with stock replacements w/o shock extenders.
thanks for the help
Old Apr 23, 2011 | 10:48 AM
SloStepSide's Avatar
I had this problem after I installed drop blocks on nissan years ago, but anyway when I got to looking I found that my u bolts where loose and everytime I hit a bumb the axle would shift. So ye might wanna check that out.
Old Apr 23, 2011 | 10:52 AM
RibeiroBJJ's Avatar
Praise The Lowered
He doesnt have U bolts....Factory 2 link with a panhard bar...How about the length of your end links...try getting the sway bar to sit level by adjusting the bolt spacers....
A stiffer shock may help as well (bilstein)
Or helper bags at ideal psi to stiffen rear a bit...try the first two first..
Old Apr 23, 2011 | 12:10 PM
Guess you learn something new everyday
Old Apr 23, 2011 | 01:07 PM
dhpro's Avatar
Did u upgrade the sway? Check the end links as well. I changed/upgraded my end links and did the Eiback sway...only so many things that could be wrong...stiffer springs, stiffer/larger sway, stiffer shocks will hold corners better and be harsher ride, and result is little more "dancing" if u hit a bump on sharp curve unless u "tune" the whole setup. Mine seems to be a decent balance with the Edelbrock IAS shocks & traction bars and similar springs to urs...
Old Apr 23, 2011 | 01:28 PM
2004SSS's Avatar
have you adjusted the panhard correct? ride height and completely centered the rear end?
also you need to see where your making contact that is the tell all.
DarkhorSe_SS
Aug 20, 2015 08:58 AM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
LoneSStar
Jul 27, 2015 09:27 PM
DONTH8
Jul 26, 2015 06:59 PM
Ketis
Jul 23, 2015 12:37 PM
