3.73 work for what I want and have?
Old Jan 2, 2015 | 06:28 PM
Ricksilvy's Avatar
4.10s at least..
Old Jan 2, 2015 | 08:24 PM
exodus_gs1's Avatar
12 Second Club
Sweet thanks everyone, its looking like 4.10 gears is in order. Jordan you broke that done in a perfect way. Makes a lot more since now. But yea an 80e is in the future just not to that point just yet lol. But thanks for all the help guys
Old Jan 2, 2015 | 10:03 PM
Jordan927's Avatar
Originally Posted by nlawson6.0
i loved my 4.56, and 3600 converter. i wasn't a dd but i would drive it 60 miles a day when it was nice out to work and all 55mph to 70mph. changed from 3.73 and would do it again in a heart beat.
-Nate
I didn't even think about 4.56's.
Yeah, that's a 115MPH 3rd at the track with 28" tires and 125 on the street with 30's
and it will only hit 2500 rpm at 70MPH
So 4.56's...Yes...these definitely win.
Old Jan 3, 2015 | 12:01 AM
brandon6.0's Avatar
I loved my 4.56s but swapped to 3.73 bc street racing was usless on nitrous with them. Was a screamer frpm a dig!!
Old Jan 3, 2015 | 09:35 AM
George C....'s Avatar
Formerly ScreamingL
recently did 488s in my procharged truck with 35s.. should put me around 120 in 4th crossing traps
still cruise at 70@2200
Old Jan 3, 2015 | 03:10 PM
bobfig's Avatar
i think 4.10s would be perfect all around. i have the same tire size and 3.73 and they are nice for a dd, i'm also in a crew cab. i'm not all modded out like you plan to but good balance for me.
Old Jan 6, 2015 | 05:01 AM
SlowDude's Avatar
Default Traction issues
3.73 here rolling on 20x10's with 31.5" of tire. I already cant get traction from a dead stop either on the street or at the track. Originally thought about 4.10 or 4.56 but sticking with the 3.73's for now while working out the traction issues... Caltracs / MT streets or bagged 4 link. I dont know just yet. I built the motor and trans to hold 300-400 shot of spray. So I feel ya man!
Old Jan 6, 2015 | 09:50 PM
exodus_gs1's Avatar
12 Second Club
What could I do besides tires to help with traction out back? I mean obviously some caltracs or alike. But what about leafs? Would like drop leafs work or removing the overload springs with caltracs work? I really like the big gear idea but yea I have never understood how people cut such good 60' with a truck
Old Jan 7, 2015 | 02:37 PM
James B.'s Avatar
What gear ratio and differential is in it now?
Does it already have a custom driveshaft?
I think the biggest concern is the differential. If it has a G80 absolutely DO NOT hit it with slicks. That will grenade the diff and take out the trans with it. If it's open it's going to be a smoke show on the passenger side, right up until the point the differential explodes from lack of lube in the pinion gears (centrifugal oil starvation).
So, take your pick from available limited slip differentials and swap that at the same time. 10-Bolts also benefit from cast differential covers since they flex under power so much. Do keep in mind that numerically higher gears are less strong because as the pinion gets smaller it has less contact with the ring gear which concentrates greater force on the teeth.
That combination of power and gearing will take your trap speed (and driveshaft RPM) well past the yielding point of the factory shaft. Replace that too.
Old Jan 7, 2015 | 08:06 PM
SlowDude's Avatar
Weight transfer is the key... Of which Im working on now!
