3/5 ?
Old Aug 2, 2009 | 10:00 PM
RickLowpez's Avatar
Default 3/5 ?
ive got a 3/4 drop and wanna go 1 more inch in rear. can i get a 3 inch shackle? will it bottom out?(04 rcsb 2wd)
Old Aug 2, 2009 | 10:14 PM
RandomHero's Avatar
No there physically isn't enough room under the bed to run a 3" shackle. the problem is that a 3" shackle isn't just 1" taller than a 2" drop shackle. Since you're only changing one mount point of the leaf spring it needs to be taller than that.
You can do one of several things:
-Take out your overload spring
-Run a drop leaf
-Run a flip kit with air shocks
Old Aug 2, 2009 | 10:56 PM
95 bright teal's Avatar
What Random said, and i would recomend a notch for anything more than 4" so you dont hit the frame all the time.
Old Aug 2, 2009 | 11:23 PM
RickLowpez's Avatar
which is the overload spring?will it ride any different?
Old Aug 2, 2009 | 11:26 PM
454navyss's Avatar
i have 3 inch springs in the front, 4 inch springs in the back and 2 inch shackles with aftermarket overload springs which makes it about a 3/5 drop. i also have my frame notched.
RandomHero's Avatar
You should have 3 leafs in your leaf pack. The bottom one is much smaller and is used for towing that is the overload. You will notice a slightly bumpier ride.
Old Aug 2, 2009 | 11:30 PM
RickLowpez's Avatar
thanks guy, does any one here have this done to there truck
Old Aug 2, 2009 | 11:32 PM
454navyss's Avatar
tons of people have taken out their overload springs.....good for helping lower the truck but bad if you still use the truck as a truck like i do
GXPJAY
Feb 13, 2022 08:15 AM
YenkoST
Aug 28, 2015 01:42 PM
Geramontes
Aug 9, 2015 09:32 PM
nightrunner
May 7, 2007 07:22 PM
Mort
Oct 25, 2005 02:37 PM
