2WD Ext Cab guys w/ 4L80e swap
Old Sep 21, 2008 | 12:47 PM
1BADAZZSS's Avatar
Yank makes converters for the stock flywheel. My Yank is specified as a sc3200 ls1 4l80e. This allows you to use the stock 3 bolt flywheel with no spacer required. My converter even came with three converter bolts already screwed in. Before I ordered it I call Yank and talk to someone there about as far as hp if there would be a problem running the three bolt flywheel instead of the 6. He said a has a blown silverado making 500+hp and is running this same three bolt converter with no problems. Only reason I went with Yank is cause I here alot complaining with vigilantes being too loose of a converter. That's just my opinion, but to each of there own.
Old Sep 21, 2008 | 01:10 PM
joshua022's Avatar
Superado...
Are you making that much power with your new set-up that your built 60e won't or didn't last??? What kind of times is it running?
Old Sep 21, 2008 | 04:36 PM
nonnieselman's Avatar
Originally Posted by Superado
what yoke is needed for the 4l60e to 4L80e swap in a 2WD Ext Cab?
is it a direct swap or is a bastard joint required?
harness adapter w/ extra speed sensor will be here today
I used a TH400 Long yoke.. trimmed it 5/8" and its all good... got new Ujoints put in, all i know is it was the same unjoint in all 3 locations..
Old Sep 21, 2008 | 06:18 PM
Superado's Avatar
11 Second Truck Club
Originally Posted by joshua022
Superado...
haven't taken it to the track or on a dyno yet...
Old Sep 21, 2008 | 11:16 PM
thunder550's Avatar
High on diesel fumes
Sorry I didn't see this sooner. I really don't have anything to add that hasn't been said already. I would definitely go to a 80E flexplate and spacer so you can use all 6 bolts. I don't know much about the yokes. The driveshaft I bought from Speed Engineering was already set up with whatever it needed to work. I didn't change any of the yokes or anything.
Old Sep 22, 2008 | 08:45 AM
Superado's Avatar
thanks...
Speed Eng. isn't offering any 80e conversion items any longer...
as a kit or separately is what they told me...
Old Sep 22, 2008 | 10:16 AM
bud8fan's Avatar
thanks...
nelson performance is doing my 80e swap as we speek...might contact allen (farmtruc) if you need assistance or parts...
Old Sep 22, 2008 | 11:29 AM
Superado's Avatar
thanks...
I think this is the yoke I need:
http://www.actionmachineinc.com/gm3r...r-3-9161x.aspx
dimensions:
http://www.actionmachineinc.com/slipyoke.aspx
do any of the sponsors sell these yokes?
Old Sep 22, 2008 | 11:47 AM
thunder550's Avatar
Did you see the thread one ls1truck about the swap? I think they discuss the yoke in there.
http://www.ls1truck.com/forums/front...rans-swap.html
Old Sep 22, 2008 | 12:10 PM
Superado's Avatar
yeah I did...thanks though...
they only address the rear-end yoke in that thread...
I am sort of confused on the whole spacer thing though
they used the spacer on the engine side with an 80e flywheel...
I know of some using the spacer on the converter side of a 5.3L flywheel...
do they both have a dish yet on opposite sides?
meaning that the spacer is needed on the converter side of 5.3L flywheel to be able to use w/ an 80e converter...
and the spacer is needed on the engine side of the 80e/6.0L flywheel in order to line it up w/ the starter from a truck originally equipped w/ a 60e?
Is going with something like the TCI flywheel the only way to eliminate the spacer?
