2wd 4l80e to 4wd
Old Dec 4, 2006 | 06:26 PM
TURBHOE's Avatar
Default 2wd 4l80e to 4wd
can you use a 2wd 4l80e to do 60e to 80e conversion in a 4wd? i was guessing just a take off the tail shaft. but what do you bolt in the place of it? the little center chunk thats between my 60e and t-case? some help here please lol.
*edit* ok i did some more research and found that the tail shaft and output shaft have to be replaced. well i was going to have to replace the output shaft anyway to be able to keep my odd ball awd t-case. but as far as the tail shaft will the 4l60e tailshaft work or are they diff bolt pattern?
Old Dec 5, 2006 | 02:05 AM
James B.'s Avatar
None of the tailhousing parts from the 60 will interchange with the 80.
Changing the output shaft requires a full tear-down. 2WD have a reluctor ring on the output carrier assembly that can stay there, you just won't be using the rear speed sensor in the trans body in a 4WD/AWD application. You'll need the tailshaft housing/adapter for the transfer case.
Output splines are different on 60vs80-E. Look to the SS guys for info on adapting the 80-E to that transfer case.
Superman09
Sep 25, 2015 05:55 AM
bisqikss
Sep 8, 2015 03:35 AM
God Made Chevy
Sep 4, 2015 12:29 AM
