2016 Silverado 1500 Driveshaft question
Does anyone have any info on what u-joints the rear drive shaft uses on a 2016 Crew Cab Silverado 1500 5.3 4wd LTZ Z71???? I have the length of the drive shaft but no measurements on the u-joints...
Last edited by SenditSilverado; 06-06-2017 at 08:12 PM. Reason: Additional info needed
Unfortunately I am offshore and do not have access to the truck. Trying to order a shaft with u-joints now so it will be assembled and ready to install when I get home.
Stock u-joints can be reused but drive shaft builder needs to know what series the stock u-joints are in order to build the driveshaft. I can't find any info on what series these trucks come with stock either. You'd think with all the driveshaft issues with these trucks someone would have some info.
2016 Silverado 1500 5.3
4wd 6L80 crew cab
Factory u-joints 1415 series u-joints
Measurements may vary depending on ride height. My measurements at factory ride height are:
71.25 rear of tailshaft to center of rear u-joint.
69" is total of shaft only.
Hope this can help anyone else looking for this info.
4wd 6L80 crew cab
