2010 Silverado 6L80e to 4L80e
Old Nov 22, 2016 | 12:06 AM
Wolftrk99's Avatar
Originally Posted by UV231 Project
I have read that the 6L80 for a 4x4 was available in a couple different models.
I am trying to gather that information for the different ones...
1. Length of trans from Bell-housing mounting surface to end of output shaft?
2. Length of output shaft from end of transmission case to end of output shaft?
3. Output shaft spline count?
https://www.powertraincontrolsolutio...Dimensions.pdf This should help.... output shaft on the 4wd is 32 spline.. i really need to bookmark that so i can find it easier!!
As for the vette output shaft, i think its at my friends house! Havent had time to go look for it, left the dealership and went back to my old job fulltime, been trying to make up some of what i am behind for the year so far....along with dealing with some other things, havent made it over to his house in a while i will hopefully get over there friday at some point and let you know....
Old Nov 22, 2016 | 09:04 AM
UV231 Project's Avatar
I read somewhere, that the output shaft on a 4x4 6L80 was different due to the kind of transfer-case used.
Old Nov 22, 2016 | 07:28 PM
Wolftrk99's Avatar
It is different on the 6l90s that were behind a duramax, but all of the light duty 1/2 ton transfer cases behind a 6l80 have a 32 spline input. Cant remember off my head at the moment what the 6l90 output shaft spline is but there are 2 or 3 different ones.
Old Nov 25, 2016 | 05:36 PM
RS/SS 4.8's Avatar
10 Second Truck Club
The 07+ 2500/3500 6.0 trucks came with the 6l90 and its a 36 spline slip yoke. The only 6l90 behind a duramax was the in the 11+ gm vans
