2009 and up 4l60e wiring
Old Jan 26, 2015 | 09:34 AM
cwalker2006's Avatar
Default 2009 and up 4l60e wiring
Trying to do an 80e swap with the frost harness in an 09 silverado. Im thinking im gonna need to wire in the old style nss because the newer trucks have the nss on the inside. Im trying to see if any of you have a wiring diagram so i can pull the wires and splice them into the old style nss to get the 4l80e working. Thanks
Old Jan 26, 2015 | 02:50 PM
pezboy's Avatar
Looking to do the same swap soon so please keep this thread updated if you find out.
Old Jan 26, 2015 | 03:22 PM
GXPJAY's Avatar
I did the swap without a Harness, was super easy, I realized I didn't really document it much, some info in my Project Thread: https://www.performancetrucks.net/fo...thread-518844/
Been working amazing for just over a year now
Old Jan 27, 2015 | 10:20 AM
Frost is making an update on his harness. Hes getting everything taken care of!
Old Feb 11, 2016 | 06:20 PM
Mean Green z28's Avatar
11 Second Club
any update?
Old Feb 13, 2016 | 07:05 AM
We used a frost harness everything is still working as it should.
Old Feb 14, 2016 | 08:31 PM
11 Second Club
so you didn't have any issue with not having the PRNDL switch connector trans in the stock harness? Everything works internal to the 4L80E? Which version of the trans? early (lines are together) or the later (separated by about a foot)? Everything points to it working with the harness, but it's not .. and we're debating running wires from the PRDNL switch on the side of the 4L80E to the Frost Harness. Maybe this harness was before the update?
Old Feb 14, 2016 | 09:11 PM
JordanH's Avatar
Restricted
The harnesses are only good for the gmt800 series... All the gmt900 trucks just need to re-pin a couple wires around in the harness and add the extra vss. Allen Nelson told me this specifically... And he makes a harness for the swap, Nelsons performance.
Old Feb 14, 2016 | 09:16 PM
JordanH's Avatar
Restricted
This is the correct and easiest way to do the 80e swap on 2007+ trucks... You literally have to swap a couple of wires around! Super easy and no need for a harness..... On the nnbs trucks
Old Feb 20, 2016 | 07:40 AM
11 Second Club
Not for the 2009+ trucks, slightly different due to the lack of a PRDNL switch on the stock trans. Unfortunately for me, my truck had the old Frost harness from 2 yrs ago that didnt quite work and that has since been "updated" to work as plug and play (may have worked in 2007-8), so mine needs a few changes done to it ... Frost is on it!
