2005 AWD - Front and rear gears interchangable?
Old Mar 16, 2009 | 08:09 AM
Rick_Vor's Avatar
Default 2005 AWD - Front and rear gears interchangable?
Kind of a newbie question but I am swapping over to a 4L80e and am thinking about picking up some 3.42's from the for sale section (currently running 4.11's). I've got a ton of bottom end torque (I hit 10lbs's at 2500 rpm) and I would like to drop my RPM's on the highway (I commute daily with the truck). I've also read that the turbo's load up even faster with taller gears. I was considering 3.73's but it's such a small drop that I didn't think it would be cost effective.
I run into a bunch of single sets but haven't had any luck finding someone with a pair of 3.42's for sale. Are all the OEM's gear sets (other than 14 bolt sets) interchangable? I don't want to pick up to seperate sets only to find out that I need a different set for the front differential.
thanks, Rick
Old Mar 16, 2009 | 08:26 AM
KySilverado's Avatar
Front sets are different. Rear are 8.6 and front are something like 7.25.
Old Mar 16, 2009 | 09:08 AM
Fronts are 8.25, rear is 8.5 or 8.6.
Pm me about you gears, I may have some you would be interested in out of my Z71, so you would have the correct front and rear sets...
Old Mar 16, 2009 | 02:47 PM
Rick_Vor's Avatar
I knew that would just be WAY too easy for them to be the same.
Thanks, Rick
Old Mar 16, 2009 | 02:48 PM
Rick_Vor's Avatar
PM sent.
Rick
Old Mar 16, 2009 | 04:37 PM
pm returned..
5.3Okasai
Mar 9, 2022 01:07 PM
Raggedz71
Jul 29, 2016 10:20 AM
gnasty1521
35
Nov 19, 2015 11:42 PM
USMCvet0311
Aug 14, 2015 10:28 PM
mrgrim
Jul 8, 2015 08:12 AM
