2002 vs 2007 4L80E
Old Mar 7, 2012 | 02:17 AM
stock48's Avatar
9 Second Truck Club
Default 2002 vs 2007 4L80E
What differences are there between a 02 and a 07 80E? Just wondering if I Can instal the valve body and internals from a 02 into a 07 case. Thanks J
Old Mar 7, 2012 | 05:15 AM
Vince B's Avatar
I don't see an issue with doing this except for when it comes to the pump. The later cases changed and if the correct pump is not used you will have cooler flow issues. IIRC this change took place in 04. If you look closely at both pumps and cases around the area where the front cooler line passage goes through the case you will see what I'm talking about here. HTH Vince
Old Mar 7, 2012 | 06:24 AM
stock48's Avatar
9 Second Truck Club
Thanks much appreciated
I thought there was something different just couldn't remember. The valvebody is my biggest concern. I want to run the valvebody and shift kit from my 2002 trans. It's the early style hd-2 kit and I like the way it shifts much better than the new style.
Old Mar 7, 2012 | 06:30 AM
Vince B's Avatar
The valve body and wiring is not going to be an issue with the 07 unit. Good luck with your project. Vince
Old Mar 7, 2012 | 01:35 PM
stock48's Avatar
9 Second Truck Club
Great news! Thanks Vince!
MikeD.
Oct 13, 2015 08:08 AM
chopperloco
Sep 28, 2015 08:40 AM
Orlerr
Sep 21, 2015 08:32 PM
spooneralmighty
Sep 11, 2015 02:28 PM
the owl
Sep 4, 2015 04:09 PM
