2" drop spindles
ok im thinkin of doing a 2\4 drop and i want to keep my ride.. im lookin into spindles, shackles and hangers.. but i have a couple questions... its says that with the spindles you need a 17"+ wheel, will my factory 17" wheel fit? and what shocks should i use or should i keep my factory shocks. is there any tips or tricks i need to know b4 doin this .. thanx
justin
justin
Go with http://www.mcgaughys.com/ spindles. yes if you have 17's they will work without cutting anything. You could get away with the stock shocks up front since it's only a 2" drop but you'll need the rears so you will be better off buying all 4 drop shocks, they are valved for a lowered truck. Doetsch Tech , Bilstein or Edelbrock are all good shocks.
I have the mcgaughy's spindles w/ 17 Escalade wheels. You should be fine with your factory 17s. I didn't need drop shocks in the front. From my understanding, the 2" drop spindles don't change geometry but just shift your front suspension up 2". My truck rides great in the front with the factory length shocks. I'm still trying to figure out how to keep from bottoming out in the rear. One question for you, do you have ecsb or rcsb?
Originally Posted by 454ss
The only way to stop the bottoming out is to C notch it...most guys I know with NBS trucks with 2-4 drops end up doing it.
its a rcsb... does anyone have a pic of these spindles on a truck and a truck with a 2\4 with stock wheels.. i know i have to change shock but i love the way my truck squats when im on it and i love the ride im not wanting to bottom out and not to bounce all over the place..i guess i might just try some bilstens..
You don't have to notch it. I have 2/4 and put Air lift slam air helper bags.
I never bottom out. The back of the truck even rides smoother with them.
