2/4 Drop And Load
Old May 24, 2007 | 09:56 AM
Silver-Dollar's Avatar
Default 2/4 Drop And Load
Will a 2/4 drop effect the amount of load you can carry in the bed? I imagine it would only effect the suspension travel and not the amount of load.
Old May 24, 2007 | 10:06 AM
beastmode's Avatar
Import Moderator
yes it will, your truck will bottom out if you put to much in. i had 2 dirt bikes in mine and it was significantly close to having the bump stops touch. infact if you do a 2/4 you have to replace the back bump stops with one thats like only 1" tall or they will touch the axle
Old May 24, 2007 | 10:16 AM
trblmkr's Avatar
IT WILL DEFINATELY EFFECT YOUR LOAD BE CAREFULL
Old May 24, 2007 | 11:06 AM
What is the appx. weight of your two dirt bikes? 500 - 600 lbs? any additional gear in there at the time?
Old May 25, 2007 | 06:51 AM
beastmode's Avatar
Import Moderator
ya probably about that... just our helmets, gloves, and boots. no like i said, it wasnt bottomin out... but at the same time i probably wouldnt have thrown 2 more bikes on there if we coulda got them to fit lol
Old May 25, 2007 | 08:22 AM
I think I can live with a 700 - 900# payload.
Old May 25, 2007 | 08:34 AM
beastmode's Avatar
Import Moderator
ya its not like you plan on going to get a yard of gravel ya know. you should be ok
Old May 25, 2007 | 08:36 AM
WJ MARK's Avatar
My buddies running a 2-4 drop on his 04 4x4, he also put some bags on it for towing heavy stuff.
Old May 25, 2007 | 11:37 AM
shakesvho's Avatar
what if you put a set of air shocks on a 4" drop, air them up when towing/loaded and when done drop the air
Old Jun 1, 2007 | 08:35 PM
Mark Johnson's Avatar
Not good, because then the load is perched upon the shock mounts, baggin' it would be the way to go.......
