18x10
Old Apr 22, 2008 | 02:17 PM
04Tahoe5.3's Avatar
Default 18x10
Does Anyone Know If A 18x10 Wheel Will Fit On The Back Of A Lowered 3/5 04 Tahoe? And Possibly What Back Spacing To Use?
Old Apr 22, 2008 | 02:44 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
18X10 6.5 backspacing. I have a 4/6 drop.
Old Apr 22, 2008 | 02:55 PM
04Tahoe5.3's Avatar
Hey Thanks
Old Apr 22, 2008 | 03:33 PM
VroomVroom's Avatar
Low LQ4, that looks awesome....but a Tahoe it ain't. There is MUCH less inner clearance against the rear suspension on the SUV. It will be very tight getting a 10" rim to fit unless you have a pretty aggressive offset spec...which means the wheel & tire will stick out quite a bit...which in turn means you're looking at pretty nasty rub&scrub against the fender whenever you hit a bump.
This is just a guess, but with a 5" rear drop and a 10" wheel, I'd say you'll need an offset spec no greater than +15mm. Compared to stock wheels, that spec would position the wheel outward by nearly 1.5". Whether or not you like that look, you're looking at trouble with scrub.
Obviously, tire size factors in a bit too, but you'd have to be very careful with the section width...you wouldn't want to go much past the width of the wheel. FWIW I ran a 3" rear drop on my '03. With 9.5" wheels @ +25mm, I nearly obliterated the fender liners whenever hitting bumps during turns. I could only guess at the difficulty of an extended fitment against a 5" drop....best of luck.
GM1697
Oct 8, 2015 11:06 AM
2 tone 02
May 14, 2015 07:56 AM
slowlsx
Apr 8, 2014 10:23 AM
sleeperlqx
Jan 26, 2014 12:25 PM
Casey2323
Nov 5, 2008 11:00 AM
