18,000 gvw tranny cooler
if its free it way better than nothing. its probably bigger than the stock one anyway so i'd use it. i got a free one from a freind when i had the silverado so i threw it right on there. i also did like gm did and keep it running through the radiator. i went into rad out of rad into cooler and back to trans. i think lol, because i wasn't sure which was which top or bottom.
i got mine at a local parts store that specialized in transmissions. the place is called transtar. but you can get them almost anywhere that they sell performance parts. you can even get them on ebay!!
http://cgi.ebay.com/ebaymotors/NEW-T...spagenameZWDVW
im using a 22,500 GVW cooler with external fan, it works great
if its all you can afford then throw it on- every little bit helps. if you have an extra 150$ id suggest the one im using
http://store.summitracing.com/partde...5&autoview=sku
also in a warm climate mount it after it passes through the rad- in a colder climate mount it befor the rad, if you live up north and you mount a trans cooler after the radiator the fluid stays pretty thick when it gets real cold out
Vortec350ss
Jan 12, 2016 10:36 PM
