14 bolt semi float 8 lug 6 lug, are they the same?
Old 08-13-2014, 11:16 PM
ecir45's Avatar
Been holding out installing OBS Z71 14 bolt being I want to get my hands on a OBS 2wd one to see how it would fit using a 6 lug 15 x 8 rally wheel. Having no such luck finding one yet though. The rally wheel is suppose to have either 3.5" or 4" bs. Don't have one of those yet either to verify bs. In due time one will pop up.
1FastBrick you ever personally measured the WMS of the OBS 2wd version? Reason I ask is a search shows atomic saying 63" while other forum searches say it is only 2.5" shorter than the 4wd version. Maybe they mean per side but don't specify.
I know my OBS 4wd is 67.5" WMS and atomics thread says 68". My NBS 10 bolt is 68.5" WMS.
Old 08-14-2014, 11:15 AM
Custm2500's Rude Friend
1FastBrick's Avatar
From What I remember the 2WD version is like 64.5 WMS.
It's been a while since I measured one. But I believe it's also been documented as such.
IIRC the axle shafts are about 1.5 inches shorter.
Old 08-14-2014, 11:37 AM
ecir45's Avatar
Thank you sir, that's a big difference. Problem I was having was trying to get a craigslist add guy to understand WMS. Axle was a 1.5 hrs away so wasn't going to make a 3 hr. trip without verification. He said his was 65" and thought wow that is the middle of what Atomics thread said between 2wd and 4wd so thought the guy wasn't measuring right.
From a visual ad if it has a good pic looks like the perches on the 2wd are allot closer to the axle flange.
Atomic if you see this would you consider updating your 14 bolt thread since it looks to be the bible every references when doing a net search.
Old 08-15-2014, 09:19 PM
ecir45's Avatar
You the man, 64.5" it is. Picked one at the local pulla today.
Just need to find some rally wheels now.
Old 08-15-2014, 09:28 PM
1FastBrick's Avatar
Thanks for the update!
I was 99% sure but it has been a while since I looked at that stuff.
And there is to many Atomics posting the wrong info...
I think I will go fix it myself...
Old 08-25-2014, 10:27 PM
ecir45's Avatar
1FastBrick, what is your experience when swapping stock carrier, gears and pinion.
Are the housing casting close enough not to have to reshim pinion depth and backlash? Would think the crush sleeve would have to be changed at a minimum.
Old 08-25-2014, 11:15 PM
1FastBrick's Avatar
I have never changed the gear set from 1 housing to another my self so I am un-sure.
For the $10 I would put a new sleeve on it. If the set up has alot of mileage a seal might not be a bad idea too.
When I pull a gear set and carrier I take all the shims and spacers with it. I have been told its usually pretty close and is alot easier then starting from scratch.
Remember despite the critical surfaces being machined, your still dealing with a casting. if there is any side shift from casting to casting you may need to adjust the side shims to get the right backlash.
Old 08-25-2014, 11:26 PM
ecir45's Avatar
I figured it wouldn't be possible but like you said a good starting point. Thanks for the reply.
Old 08-25-2014, 11:36 PM
1FastBrick's Avatar
On 1 set up, the pinion depth looked good but the side shims needed adjusting from what I was told.
Old 08-26-2014, 07:53 AM
ecir45's Avatar
That's a plus not having to remove bearing .
Quick Reply: 14 bolt semi float 8 lug 6 lug, are they the same?
