14 bolt question.
Old May 15, 2016 | 12:15 PM
fastoyzz's Avatar
Default 14 bolt question.
Ok need a little info. I cant seem to find a straight answer. I have a 06 silverado 10bolt that's busted. I found a 99 z71 classic. It has a 6lug 14bolt from the factory. Will this be a direct bolt in using my brakes and with a u joint swap? Thanks in advanced fellas!
Old May 15, 2016 | 08:46 PM
02singleturbo's Avatar
Spring perches will have to be cut off an moved out 1 in on both sides
Old May 15, 2016 | 11:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It has been documented several times on this site.
If it's from an OBS GMT400 4x4 truck, it will be 1/2 in shorter on each side, and as mentioned the spring perches will need to be moved inward.
If it's from a 2WD leave it behind. It will be 1 1/2 inches shorter on each side and may pull the wheels in too much.
Old May 16, 2016 | 11:14 AM
fastoyzz's Avatar
Sorry fellas i dug for hours trying to find info
Guess i was blind. Just bought a 05 vho 410
rearend that i found. Thanks for ya'lls help
Old May 16, 2016 | 11:51 AM
1FastBrick's Avatar
That will bolt right in!
Old May 16, 2016 | 12:30 PM
tgui's Avatar
Where did you find it?
Old May 16, 2016 | 01:14 PM
1FastBrick's Avatar
Since no one ever looks in the sticky thread... See this thread for info.
https://www.performancetrucks.net/fo...thread-467473/
Old May 16, 2016 | 02:52 PM
tgui's Avatar
Actually I wanted to know where he sourced the rear end. I seem to have bad luck.
Old Jun 4, 2016 | 02:38 PM
fastoyzz's Avatar
Found it @ a local bone yard with 90k miles. Now the problem is a universal joint. Looking for a part # for one. The truck is a 05 crew cab 2wd with a 1piece aluminum drive shaft. Ive researched the sticky thread on here since i started the project. The part stores cant seem to find a universal joint that fits.
Old Jun 5, 2016 | 01:04 AM
1FastBrick's Avatar
According to Atomic's thread:
U-Joint:
- If your driveshaft is a 1330 (I have the big aluminum one which is a 1330 with the 1.0625" caps), then you need a 1330 to 1350 conversion U-joint which I could only find on Jegs
- If your driveshaft is a 1310, you need the 348 conversion U-joint (1310 to 1350)
- If your driveshaft is an R3 SS4, you need the 447 U-Joint (ss4 to 1350)
- For most people, im guessing the ones with the two piece steel driveshafts, you need the 447.
