14 bolt axn 2 piece drive shaft
Old Mar 19, 2019 | 09:32 AM
Maverick616's Avatar
Default 14 bolt axn 2 piece drive shaft
Hello I am new to this board and recently finished a turbo build. Appreciate any help to the following.
Was planning on doing the 14bolt axn axle up grade on my 03 Ecsb Silverado. Was wondering if anyone knows if this will bolt up to my 2 piece drive line without modification. I believe the 14bolt is 1350 and my drive shaft is gm3r so I would need a conversion u joint. Just trying to figure out if I will need to lengthen or shorten my drive shaft to make it fit.
Old Mar 19, 2019 | 01:22 PM
zz454Chevelle67's Avatar
I don`t have a 2 piece driveshaft but when I swapped in a 14 bolt AXN rear axle I just used a conversion U joint and did not need to shorten the shaft.
Old Mar 20, 2019 | 06:10 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Conversion Joint yes.
If your stock height likely you won't need to shorten the drive shaft.
The Factory AXN equipped trucks where 5/8 of an inch shorter on the rear shaft than a 10 bolt truck.
Old Mar 20, 2019 | 08:14 AM
The truck has a 4/6 Djm drop kit installed. If it is too long I figure I would need to remove it and take to driveshaft shop to shorten, balance.
vmaxpro
May 5, 2017 09:03 PM
pasadenaman
Jun 23, 2012 04:10 PM
SLO TRUCK
Nov 30, 2009 10:11 PM
gmforlife
Mar 11, 2007 11:19 PM
