14 bolt axn 2 piece drive shaft
Hello I am new to this board and recently finished a turbo build. Appreciate any help to the following.
Was planning on doing the 14bolt axn axle up grade on my 03 Ecsb Silverado. Was wondering if anyone knows if this will bolt up to my 2 piece drive line without modification. I believe the 14bolt is 1350 and my drive shaft is gm3r so I would need a conversion u joint. Just trying to figure out if I will need to lengthen or shorten my drive shaft to make it fit.
Conversion Joint yes.
If your stock height likely you won't need to shorten the drive shaft.
The Factory AXN equipped trucks where 5/8 of an inch shorter on the rear shaft than a 10 bolt truck.
pasadenaman
Jun 23, 2012 04:10 PM
SLO TRUCK
Nov 30, 2009 10:11 PM
