08 silverado gear oil
Old Jul 17, 2012 | 11:03 AM
ivan_key's Avatar
Default 08 silverado gear oil
Ok I have a 08 silverado with a 10 bolt. I'm installing 4.11 gears and a value trac in it tonight. I'm wondering what fluid should I go with and how much. Also does these value trac's need any sort of limited slip additive or anything. Thanks for any input
Old Jul 25, 2012 | 05:35 PM
canada4g63's Avatar
Mobil-1 75W-90 or SAE Synthetic 75W90, just shy of three quarts.
Old Jul 25, 2012 | 07:09 PM
Ferocity02's Avatar
You MUST run conventional oil, no additives. If you run synthetic then the diff may not work correctly. I use Valvoline 75w-90 with mine.
I was only able to get about 2.5 quarts in mine, and that was almost up to the fill hole. My diff is pointing down more than stock though so the oil level reaches the fill hole faster.
Remember to change the oil after 500 miles. The first drive is VERY important. Light easy driving for ~30 minutes, then let cool completely overnight. Refer to the pt.net gear swap sticky.
ferrellrooster
Mar 6, 2025 03:22 PM
chopperloco
Jul 10, 2016 10:45 PM
B.love18
Sep 21, 2015 08:31 PM
Ketis
Jul 23, 2015 12:37 PM
smit2732
Jul 19, 2015 01:43 PM
